1/25/2011 11:40 AM | |
Posts: 46 Rating:
Hi, My case similar to him, which I am trying to establish the modbus TCP/IP connection between S7315-2PN/DP and PCB board (other supplier). The port number of PCB board already fix in 502, so i have to change my siemens CPU port number. Am i just change port number to 1001 in the DB2 "Modbus_Param" local_tsap_id[1] = 3, local_tsap_id[2]=E9? That's enough for the configuration? Vince Splitted from CPU 315-2 PN/DP Port Setting Problem. |
1/26/2011 2:39 PM | |
Posts: 3093 Rating:
Hello Vince, why don't you use the wizard? http://support.automation.siemens.com/WW/view/de/31535566 Regards, Kaulquappe |
