10/17/2017 12:22 PM | |
hi, have you seen the application samples for the communication module 6GK7 242-7KX30-0XE0: Application Samples for CP1242-7 hope this helps, regards, |
FCK WAR! |
5/18/2022 5:13 PM | |
Joined: 4/11/2022 Last visit: 7/31/2022 Posts: 1 Rating:
hello , |
10/2/2023 2:31 PM | |
Joined: 9/11/2019 Last visit: 2/21/2025 Posts: 1 Rating:
Helloachraf-ayat Did you solve your problem. I also want to make a phone call from the S7-1200 system. Thanks ¿? |
10/3/2023 7:40 AM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello,
you can easy try also search on Forum for your expected solution. This is result: CP 1247-1 phone call possibility Search results |
With best regards... |
