9/22/2013 10:27 AM | |
Hello, The ET200B is not modular by nature as a ET200S for instance is. I inserted the ET200B in a test project, and by playing around i discovered that the default configuration creates the device as a block of consistent data. But it seems that you can change the configuration to access each channel individually. Have a look to the document in annex. In my opinion you can now access each channel as done ususally. I do not have an ET200B to test this. Let us know. AttachmentET200B parameters.pdf (87 Downloads) |
Best regards |
