10/26/2006 2:23 PM | |
Joined: 4/24/2006 Last visit: 6/9/2023 Posts: 8587 Rating:
Hello alexfizeau, When you have a CPU as DP-master, you can do the following: L PIW 272 T MW 100 But it's also possible to use FC105 'Scale', see following faq: http://support.automation.siemens.com/WW/view/en/1765297 Hope this will help. Best regards, Wizard |
10/26/2006 3:31 PM | |
Hi, Ok, I get the point ![]() Here is a manual: http://support.automation.siemens.com/WW/view/en/23988528 Did you have a look at chapter 11.9 etc. Hope this will help. Best regards, Wizard |
