9/30/2016 11:27 AM | |
Joined: 2/27/2014 Last visit: 4/20/2023 Posts: 688 Rating:
Hello, See the attached sample code for Modbus Master 1SI module. Suggestion would be, 1st try with Modbus tester software *(eg Modview/Modscan) to check everything is working or not. Then only connect meter with 1SI module and check. If you feel this post is useful then don't forget to rate. Attachment1Si.zip (111 Downloads) |
With Best Regards, |
