6/10/2013 3:45 PM | |
Posts: 27 Rating:
What if i am using STEP7 TIA V11 SP2 i am not getting desired outout. That blocks are not working at all eventough i am getting the same results in case i am using step7 simatic manager v5.5. |
Last edited by: O_Moderator at: 6/13/2013 8:02 AMnew subject after splitting from /tf/WW/en/Posts/63921#top |
7/13/2013 12:37 PM | |
Joined: 5/28/2008 Last visit: 6/6/2023 Posts: 4448 Rating:
Hello, Please check that in HW configuration the AO channel is set to 1-5 V. Hope this helps.
Ayman Elotaify |
7/15/2013 7:35 AM | |
Joined: 11/18/2010 Last visit: 8/5/2022 Posts: 523 Rating:
if your HW config properties properly set as per requirement and you are forcing some count value manually to AO and still you are not getting o/p then AO is faulty, VP |
