1/7/2015 9:44 AM | |
Joined: 8/31/2005 Last visit: 4/24/2023 Posts: 2194 Rating:
If you want to do Motion Control via pulses (with Siemens), you should use a S7-1200 (or a S7-200). The only ET200 module I know that may supports this too is the 2 PULSE module (6ES7138-4DD00-0AB0),look herehttp://support.automation.siemens.com/WW/view/en/6138329 |
1/9/2015 3:33 PM | |
Joined: 3/25/2012 Last visit: 10/6/2022 Posts: 99 Rating:
Thanks miami.I will try this..and let u know the result |
