10/19/2015 2:04 PM | |
hi, it is not really clear what you want. What ServicePack of Step7 5.5 do you have? Try to install the latest to get the ET200SP projected. Service Pack 4 for STEP 7 V5.5 and STEP 7 Professional 2010hope this helps,regards, |
FCK WAR! |
10/19/2015 2:54 PM | |
Posts: 4 Rating:
Already running SP4 Here's the DB for the ET200S example.(The ET200SP uses two bytes per slot) How do you decide what the two version numbers should be? |
10/20/2015 4:39 PM | |
Posts: 4 Rating:
Using the version info coding I've coded and tested my example. All good. Thanks. |
