11/5/2012 3:48 PM | |
Posts: 4 Rating:
Hi, I'm using win 7 32 bit. Yes ı'm admin |
11/5/2012 4:09 PM | |
Joined: 12/12/2008 Last visit: 12/12/2022 Posts: 17 Rating:
TiaPortal V10.5 is not compatible with Windows 7. see: http://support.automation.siemens.com/WW/view/en/51120883 I suggest you upgrade to the latest version = V11SP2 upgrade 4. |
Productspecialist Industrial Automation |
11/5/2012 4:47 PM | |
Posts: 4 Rating:
But the program can work. Means, if didn't compatible with Win7 it wouldn't work, ı think. Also, ı can try another pc and ı achieved.. |
11/7/2012 8:42 AM | |
Posts: 4 Rating:
Thanks for the information. I see. Then, do you know that TIA PORTAL V10.0competiblewith Win7 32 bit?And how can ı download SP2 TIA? |
11/7/2012 9:44 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Hello, Tia portal V10.5 is not compatible with any version off Windows 7, see link posted before Compatibility list of STEP 7 (TIA Portal) and MS Windows Tia v10.5 can not be upraded to V11, you need to buy it. Regards, Marcjan |
Problem solved? |
11/7/2012 11:36 AM | |
Hello, I see but nowhere to download for free, so best to contact local Siemens support. Regards, Marcjan |
Problem solved? |
