9/19/2012 6:07 PM | |
Posts: 6 Rating: (0) |
Dear All, With reference to the above mentioned subject, please note that I need some help to establish communication settings and configuration and procedure for ethernet communication between S7-200 Plc's (One master and 6 slave plc's). Also find attached the network architecture dwg for the same. Also kindly send me a sample program as per my requirement. Your kind help in this regard will be highly appreciated. Thanks and Regards, Kamran.
AttachmentC:\Documents and Settings\sa922486\Desktop\network architecture.pdf (274 Downloads) |
9/19/2012 7:26 PM | |
Joined: 4/22/2010 Last visit: 2/15/2024 Posts: 5697 Rating: (711)
Hello, Have a look at Micro Automation: Networking automation systems via Industrial Ethernet (MAS 14) Communication between 2 S7-200 with example projects and more usefull stuff. Regards, Marcjan |
Problem solved? |
2/5/2013 3:10 PM | |
Posts: 3 Rating: (0) |
Kamran, I am having the same problem that you described. I was wondering if you ever found a solution to the issue and what you did. |
3/18/2014 8:09 AM | |
Joined: 3/1/2009 Last visit: 4/4/2024 Posts: 6 Rating: (0) |
Please, inform, are there any solutions for this question? Thank you!
