3/29/2012 5:55 AM | |
Joined: 10/7/2005 Last visit: 3/18/2025 Posts: 3042 Rating:
Hello sk83 Yes, you can do data exchange between the two S7 CPU's via each 343-1 LEAN CP. I suggest you usean ISO-on-TCP connection for this purposes and you'll find all required info and examples on how to do so in the two links below: How do you configure an ISO-on-TCP connection for data exchange between S7-300 and/or S7-400 by way of Industrial Ethernet CPs? SIMTIC NET Quick Start examples I hope this helps |
Cheers |
3/29/2012 4:19 PM | |
Posts: 1547 Rating:
Hello sk83, the CP343-1 LEAN can only act as Server for S7 communication. So it's not possible to use PUT/GET between two Lean CPs. |
3/30/2012 5:35 PM | |
Joined: 6/6/2011 Last visit: 3/12/2025 Posts: 9 Rating:
Thanks For your info, I will to try it. |
