6/5/2020 4:30 PM | |
Joined: 6/5/2020 Last visit: 7/27/2022 Posts: 8 Rating:
Hi, is it possible to have the link where i can find the Example Image for the IOT2050? I have tried to connect with my pc to the device but unfortunatelly i cannot establish any connection to the ip address 192.168.200.1. Thanks. Best Regards Stefano ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/08/2020 08:38:50New subject after splitting |
6/8/2020 12:13 PM | |
Hi Dirk, thank you for the info, i will have a look. cheers |
6/10/2020 5:48 PM | |
Joined: 9/29/2011 Last visit: 7/21/2022 Posts: 3 Rating:
Hi: I follow the instructions https://support.industry.siemens.com/tf/ww/en/posts/how-to-build-github-example-image/237116/?page=0&pageSize=10 and https://github.com/siemens/meta-iot2050 to build images. I tried both images (example and RT example) on IoT2050 Basic and got no response on screen and 192.168.200.1. The STAT light is solid red. I use a 32GB micro SD HC. Please would you give me some helps to solve my problem. Thanks and Best Regards, Tony Hung |
8/4/2022 9:02 AM | |
Joined: 4/28/2015 Last visit: 8/12/2022 Posts: 2905 Rating:
Hi, the Example Images can be found here. Please post your next question in english language, that everybody is able to understand and help you. Best regards! |
