7/8/2015 8:53 PM | |
Posts: 1 Rating: (0) |
HI I need to do a program that read and write to a CPU S7-1200, alert by Excel using VB, I tried to use this Link but the object creation error. Can anyone help me? Thanks. |
7/9/2015 10:51 AM | |
Posts: 1058 Rating: (93) |
Hello Cassio_Lemes, the link you provided is not working. I guess you meant that: How do you create an OPC client with Microsoft Excel?
Have you read that before? How do you connect a PC station to an S7-1200 with OPC? You see that SIMATIC NET DVD V12 is required for communication. I suppose you do not have it installed and therefore get object creation error. There is also an example program you should check: Simple Plant visualization with OCX Data Control in VBA for Excel
regards
