3/11/2009 10:47 PM | |
Posts: 2661 Rating:
Hi Profimus, The first thing you should confirm is, the WinCC stations that you call "clients" are indeed WinCC clients connected to a WinCC server or 2 standalone WinCC stations. If they are really WinCC clients connected to a server youneed not establish a communication between the clients. On the other hand if they are standalone stations (and I believe this to be the actual case) you should useOPC for data exchange since WinCC has a built-inOPC client/server. The following FAQ will be helpful for this: Steps required for setting up an OPC connection (WinCC V5.0 SP2)
