1/26/2011 10:34 AM | |
Posts: 40 Rating:
Can you explaine this a little bit more ?? |
1/27/2011 8:23 PM | |
Posts: 40 Rating:
Ok, thanks... i did what you suggested... I understood first solution, and i uploaded picture1, so please tell me is that ok, did I do what you told me to ?? About second solution, i have a problem. That FOR loop, that you send me, how can I write it in OB1?? what is the syntax?? And about that average time, I uploaded Picture2, so please look if that is the right setting?? Thank you. BR, Goran. AttachmentMy Pictures.zip (185 Downloads) |
1/28/2011 10:23 AM | |
Posts: 40 Rating:
Ok, thank you. So what do you think, which method is better and more accurate?? |
1/28/2011 2:23 PM | |
Posts: 2348 Rating:
First, if program contains not much branching. Second is also pretty accurate, but what is much more important - it requires less time from programmer:^) |
1/31/2011 7:02 AM | |
Posts: 2348 Rating:
yes - it's the same:^) |
