3/29/2023 9:09 AM | |
Joined: 1/21/2013 Last visit: 4/24/2025 Posts: 3775 Rating:
Hi, Have you checked whether the export file is created by using the file browser on the Unified Comfort Panel or after unplugging the USB flash drive on your computer? I ask because it's a known issue that there is no way to safely eject USB sticks. Since V18 you can use the IsDirectory method to check if the mounted directory exists. This would allow you to detect an inserted USB stick Kind regards |
