10/24/2012 5:01 PM | |
Posts: 3037 Rating:
Hello GoForIT, |
10/25/2012 11:56 AM | |
Posts: 3037 Rating:
Hello GoForIT, You can store this CSV file on a PC. Or you can use a function to copy the file about network to the PC. How do you integrate an HMI operator panel into a local network? Or you can use the option Sm@rt server, which this option can you look from a PC to a panel and you can control the panel or you copy this file to your PC. You can use a panel as OPC-XML-DA-Server for process value communication. OPC Tweety |
10/26/2012 6:18 AM | |
Posts: 352 Rating:
Thank you, Your help has been helpful Ola |
