6/16/2014 5:38 PM | |
Posts: 1 Rating:
Hi, I wish to configure a connection between a CP 343-1 Advanced (GX21-0XE0) as PROFINET IO controller and a ET200S HF (IM151-3, 3BA22-0AB0) as IO device using TIA PORTAL v12 SP1 Update 4. A dialog box shows the extended PN diagnostics is not supported by the IO controlller and I cannot make the connection (the IO device shows "Not assigned" in Network view). I have seen the linkhttp://support.automation.siemens.com/WW/view/en/23678970and I have verified this fact, but also says that there is a migration GSDML file for some of the devices listed for operating with IO controllers without extended PN diagnostics support. I have been looking for this GSDML file to my ET200S but I have not found it. Does this file exist? Is there any solution for configuring this connection? Thank you. Regards.
