4/30/2012 12:15 PM | |
Joined: 4/30/2012 Last visit: 2/26/2025 Posts: 55 Rating:
How to configure external encoder with SIMOTION for positioning application? |
4/30/2012 12:25 PM | |
Joined: 5/12/2006 Last visit: 4/17/2025 Posts: 22620 Rating:
Hello, please specify your question. With only a external encoder you can't positioning. Regards Christoph |
4/30/2012 12:47 PM | |
hi i want to configure encoder_2 with SIMOTION D410 which gives positioning count to the axis of motion task. |
4/30/2012 1:12 PM | |
Joined: 10/11/2006 Last visit: 4/17/2025 Posts: 6008 Rating:
Following your enquiry "How to configure external encoder with SIMOTION for positioning application? " we need some more information? 1. Platform: which simotion do you use ? --> 2. where should the external encoder be connect? (DriveCliq; PROFINET; onboard ...?) 3. using DSC? (when using DSC --> AxisConfiguration Data must be set --> encoder DSC ?) If we got some more information, Iwill send you example-Program or Information with screenshoots from necessary configuration. (Let me know the versionfrom simotion scout) . best regards Otto mailto:tech.team.motioncontrol@siemens.com |
With best regards, |
