12/30/2013 10:11 AM | |
Joined: 10/11/2006 Last visit: 2/3/2023 Posts: 5412 Rating:
Hello, zero mark is not possible. It is possible to set the position to zero. In case of endless moving axis you get a position overflow, because the max. position value is 32 bit. Maybe a speed synchronising is enough for your application. Pulse/direction signals Page 178 http://support.automation.siemens.com/WW/view/en/66206528 |
With best regards, |
