3/28/2019 8:53 AM | |
Joined: 9/21/2012 Last visit: 6/9/2023 Posts: 3722 Rating:
Inadequate cooling in the panel? |
3/28/2019 11:12 AM | |
hi Juha, Also check the correct mounting of the ET200SP-station. The figure below shows the minimum clearances you must observe when installing or dismantling the ET 200SP distributed I/O system. This is neccessary to get the rejected heat away. You can find this information in this manual, chapter 5: SIMATIC ET 200SP Distributed I/O system hope this helps, regards, |
