5/11/2014 3:08 PM | |
Joined: 1/28/2009 Last visit: 3/8/2025 Posts: 6860 Rating:
For compliance with safety standards on PROFIBUS,any device or coupler that are used in the network should support the PROFISAFE Profile.It will be helpful to read more in "SIMATIC Bus links DP/PA coupler, active field distributors, DP/PA Link and Y Link" , if they support the option.Still, you can check configuration tips for a Fail-safe slave plus all programming blocks HERE.
I hope this helps, Hamid Hosseini |
