4/8/2021 5:57 PM | |
Joined: 11/2/2017 Last visit: 4/17/2024 Posts: 29 Rating: (0) |
Hello, Did anyone find the solution for this issue? I am also having similar issue. It runs fine usually but if it happens it will give error at least 2-3 times a day the device gives F60 error. Or else it won't give error for few days. We tried using EMC Filter as well, it worked fine for a while but again started getting the same error. Is there a permanent solution for this error? Is it something to do with hardware itself? [snip] Kindly suggest. Regards, Rahul ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/09/2021 08:50:01New subject after splitting. Division of question into separate topics. |
