1/24/2025 9:56 AM | |
Joined: 1/21/2013 Last visit: 2/11/2025 Posts: 3535 Rating:
Hi, What you are describing looks like a bug to me. So you should report this behavior to technical support by creating a support request. Unfortunately, until a fix is provided, you will not be able to use the feature as intended. But to be honest, I am not sure which behavior is the right one. It may also be that the PC Runtime is now behaving correctly. Kind regards |
