7/3/2018 1:01 AM | |
Posts: 20 Rating:
Hello Isas, I use this kind of solution if i have many objects that i want to view data from. Made one example project with 5 engines to show information on 1 faceplate. Made in TIA Portal V15 Update 2. Hope you can get some tip from it, on the road to your goal. //David AttachmentIndex UDT.zip (690 Downloads) |
10/20/2018 3:00 PM | |
Joined: 12/3/2013 Last visit: 4/30/2024 Posts: 51 Rating:
Did you find any solution for this? I have also the same issue. |
