8/29/2016 9:54 PM | |
Posts: 439 Rating:
Hello Mad4Swift, I did faceplate with WinCC Advanced/Comfort V13 SP1 in the past and create a procedure for the future. Never tried to do it with Professional version, but maybe this will help you. Best regards, Hugo AttachmentFaceplate et UDT HMI_EN.pdf (89 Downloads) |
8/30/2016 8:28 AM | |
Joined: 8/3/2009 Last visit: 9/28/2023 Posts: 11282 Rating:
Hello Mad4Swift in WinCC Professional you work in a different way with this as in WInCC Comfort/Advanced Here you find a good example of what you need: https://support.industry.siemens.com/cs/de/en/view/109339757 Bye Murof |
