10/29/2020 12:46 PM | |
Joined: 2/12/2018 Last visit: 12/15/2022 Posts: 21 Rating:
Hi geri036, The attachment show an example about how to do it with a toggle button. The code should be split between Global defenition and Script function (as the example shows) hope that helps AttachmentPopUp_Faceplate_Once.zip (418 Downloads) |
6/25/2021 9:16 AM | |
Joined: 2/13/2020 Last visit: 1/28/2023 Posts: 54 Rating:
Hi Geri The function po.Close() is only available from V17, since the images are not released yet your panel is still V16, you need to firmware upgrade your panel ones the images are released to get it working properly. https://support.industry.siemens.com/cs/ww/en/view/109746530 Hope that helps somewhat |
7/2/2021 2:27 PM | |
Posts: 152 Rating:
I got image update V17 but still I can not get it to work. Anybody have any idea? |
