1/16/2018 6:00 AM | |
Posts: 5 Rating:
Hi All, Thanks in advance for any solution..! Im using ET 200M module in my RIO with OBT for conversion of F.O signal to Profibus signal. Now im facing a problem of all DI and AI Signal flicker for about 500ms with unknown flickering time. Tried changing power supply module,OBT,ET 200M and All DI cards.But the problem still coming. Looking forward for any good suggetion....! ------------------------------------------------------------------------------------------ |
Last edited by: Dsouza at: 1/16/2018 6:00:26 AMLast edited by: Jen_Moderator at: 1/16/2018 1:46:59 PMNew subject after splitting |
1/23/2018 9:28 AM | |
Posts: 33 Rating:
What exactly do you mean by "Now im facing a problem of all DI and AI Signal flicker for about 500ms with unknown flickering time." this statement. Is one flicker (on/off state) exactly for 500 ms? On the other side check if your Interface modules have ACT (active) led going off during the flickering period. If it does then its a good idea to also check the fiber optic cable to OBT is lossless and have the correct length/type as recommended in the documentation.
