5/27/2011 9:57 AM | |
Posts: 691 Rating:
I also facing some problems with the PLCSIM V5.4 SP3 , when it comes to H Systems. The first time when you download , it will work fine, But the second time it will ask for which node address and then gets hanged Splitted from PCS7 WITH PLC SIM THROUGH NAMED CONNECTION . |
5/27/2011 11:25 AM | |
Posts: 691 Rating:
OK first you download the hardware and then again download the Hardware What you get. I am faving the problem at that moment |
5/27/2011 6:09 PM | |
Posts: 947 Rating:
Plcsim not support named connection p.s. You can use PLCSIM 5.4SP4. |
