6/16/2012 2:00 AM | |
Joined: 10/7/2005 Last visit: 9/28/2023 Posts: 2988 Rating:
Hello sivabalan100 404 what the pbm is, but it would be gr8 if u could give us more detail. Ok ,enough of the text message shorthand nonsense which neither helps in understanding your orginal question, nor any answer. Start by having a look at the CPU's Diagnostic Buffer and shouldthe infomartion in it does not help you, save it as a text file and upload it here. Please give us also more detail on your configuration and program. For example: -what actuators are connected in which way to 4 F-FQ module (perhaps you can provide us with a sketch) - what's you F-program's call rate and monitoring time (ideally provide us with a copy of your S7 program) -did this application work before and now started to fail all of sudden - etc. etc. The more detail you can give us, the easier it is for us to give you meaningful advise. I hope this helps |
Cheers |
