8/14/2014 7:53 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, When a card is passivated after detecting a faillure depends on the settings in the hardware configuration. So we need to know what settings you use and how things are connected to the module. you can read more in the following link, you learn how to setup and wire the card, maybe you can find the problem on your own. SIMATIC Safety Integrated for Process Automation Wiring and Evaluation Architectures for Failsafe Digital Input (F-DI)- and Output-Modules (F-DO) of ET 200M Regards, Marcjan |
Problem solved? |
