2/13/2025 1:39 AM | |
Joined: 10/16/2017 Last visit: 3/17/2025 Posts: 42 Rating:
As you can see, nothing showed up in the job parameters section after I clicked to open the report template. |
2/13/2025 5:58 AM | |
Joined: 1/21/2013 Last visit: 4/30/2025 Posts: 3782 Rating:
Hi Ew Chee Yean, Can you please explain how you imported the report template? Your current description sounds to me like you just put the file in the local home path. But you need to import the template by clicking "Add new" in the "Job parameters > Templates" tab of the "Reports" control. Kind regards |
2/13/2025 6:47 AM | |
Hi Ew Chee Yean, Look at the status bar of the Reports control. You should see status and error information. Unfortunately, your screen appears to be configured for a larger device, so you may need to scroll or zoom the screen. You may also find it helpful to use the Trace Viewer. Kind regards |
