7/6/2022 2:53 PM | |
Joined: 12/13/2013 Last visit: 2/25/2025 Posts: 136 Rating:
Sorry for late answer, I have attached the screen shoot thanks |
We Keep Your Plant Running |
7/7/2022 1:27 PM | |
Hello I would try to reset the temporary files and test again: https://support.industry.siemens.com/cs/de/en/view/109778709 Can you simulate with a new test project or is this here the same behaviour? Bye Murof |
7/11/2022 11:34 AM | |
Joined: 2/17/2020 Last visit: 4/16/2025 Posts: 1250 Rating:
Hi, I see that you have TIA V16 installed (without any Update) in a Windows 10 Pro 21H2 environment. Please, to ensure that it works in a released environment, try to install the latest TIA V16 Update: Updates for STEP 7 V16, S7-PLCSIM V16 and WinCC V16 Note: Support for Windows 10 Pro 21H2 starts from Software -> Update 4. |
A rating will be well appreciated. |
7/13/2022 4:29 PM | |
Hello ! Murof, Thank you for your support . My problem is solved by installing update 5. |
