8/4/2010 10:02 PM | |
Joined: 5/28/2008 Last visit: 9/9/2024 Posts: 4515 Rating: (839) |
Hello, It is clearly stated in the manual of High Speed Analog Input Module 6ES7 331-7HF01-0AB0that the basic coversion time per chanel is 52 micro second. Hope this helps. |
Ayman Elotaify |
8/7/2010 8:15 AM | |
Joined: 7/28/2010 Last visit: 8/31/2024 Posts: 184 Rating: (11) |
Kusuma, You better select a vibration sensor which gives you4-20mA Analog Output Signal. Regards, Behnam www.sigmaprocess.ca |
10/19/2010 12:00 PM | |
Posts: 4 Rating: (0) |
Dear Sir, Thanks for your reply and suggestion I am buying this model and I am going to experiment on this regards Kusuma.N Sc-D |
10/19/2010 12:04 PM | |
Dear Mr Behnam R Thanks for your suggestion, I am going to buy this model and experiment with 4 to 20 mA as well as 0 to 10V sensors Regards Kusuma.N Sc-D |
