4/18/2019 11:42 AM | |
Joined: 10/11/2006 Last visit: 12/8/2023 Posts: 5725 Rating:
Hello, check out the following FAQ`s for help regarding F08501 and the response time monitoring on PLC side. https://support.industry.siemens.com/cs/ww/en/view/109748624 In case you want to change the fault reaction you can find an example on the following SIOS link. https://support.industry.siemens.com/cs/ww/en/view/70891736 |
With best regards, |
4/18/2019 3:02 PM | |
Joined: 2/8/2018 Last visit: 3/28/2023 Posts: 256 Rating:
Also i want to mention here that the Bus fault is also blinking once the fault comes |
4/19/2019 1:33 PM | |
Any suggestion??? hardware configuration , telegram and cable is ok. still bus fault iscoming |
