8/16/2013 5:53 AM | |
Posts: 2 Rating: (0) |
Dear all, I have two anolog output modules 332 5HF00 0AB0 in CPU 313 DP . One of them working ok without any problem. Another one has signal fault indicator bright every time. When I swap position and connection of two modules, this fault indicator not eliminate. I use diagnos this module in hardware from computer: External error Faulty module No external auxillary voltage I thinks this module have problem, not connection or hardware config. How could I do, please help. Thank you very much
AttachmentAO fault.pdf (265 Downloads) |
9/28/2015 8:13 AM | |
Joined: 4/14/2015 Last visit: 7/25/2024 Posts: 8 Rating: (0) |
Hi , Did you got any solution ... bcoz I am facing the same problem |
