9/25/2008 3:16 PM | |
Posts: 1 Rating:
Hi, Can we create fault tolerant connection for S7 400H system using CP1612 ? If yes then how?... & we have also Red connect at PC end. Nanji |
9/25/2008 3:42 PM | |
Posts: 487 Rating:
It is not clear what application on PC you want to communicate with. WinCC? SimaticNet OPC?. Please be specific as there are some changes in communication configuration. Also what software do you have on your PC? Step7 or NCM PC? There is no much difference between configuration steps in there two softwares. Here are some helpful links http://support.automation.siemens.com/WW/view/en/24135493 http://support.automation.siemens.com/WW/view/en/16651010 http://support.automation.siemens.com/WW/view/en/16667714 |
9/25/2008 4:39 PM | |
Posts: 487 Rating:
Thank you "not_my_fault" for pointing the CP part#. I overlooked it in the original question. Redconnect is supported onlyby CP1613,CP 1613 A2 andCP1623 |
