5/9/2019 4:11 PM | |
Posts: 24 Rating:
Hello. Were you able to use FB640 and FB641 blocks with your S7-300 successfully Thanks ------------------------------------------------------------------------------------------ |
Last edited by: ClouSiemens94 at: 05/10/2019 04:53:23Last edited by: Jen_Moderator at: 05/10/2019 08:53:41New subject after splitting |
5/10/2019 1:48 PM | |
Joined: 7/9/2015 Last visit: 3/20/2025 Posts: 4202 Rating:
Hi, the Modbus instructions should work on S7-300. So you can check if you have newest version of the FB - and you can check / post diagnostic buffer of plc for which reason the CPU has gone into stop. Check this link: PtP instructions for use of ET 200MP / ET 200SP in the distributed peripherals of a S7-300/400 with Step 7 V5.5Regards, Towome |
5/13/2019 10:53 PM | |
Posts: 3093 Rating:
Hello, Master-Slave Communication with Modbus RTU for S7-300 and ET 200S Systems Regards, |
5/14/2019 5:14 PM | |
Posts: 24 Rating:
Hello,could you please help me up with this? |
