4/16/2008 9:14 AM | |
Joined: 9/27/2006 Last visit: 7/26/2024 Posts: 12270 Rating:
Hello paskaloglu; The CP 5611 (and its replacement, the CP 5611 A2, or its PCI Express equivalent, the CP 5621) supports FDL communications. So, if you already have the C libraries you mention, all you should need is a manual exlaining the FDL Programming interface functions: https://www.automation.siemens.com/doconweb/pdf/SINUMERIK_SINAMICS_10_2007_E/sinec_fd.pdf?HTTPS=REDIR&p=1 Hope this helps, Daniel Chartier |
