10/10/2017 8:56 PM | |
Joined: 3/10/2017 Last visit: 7/14/2022 Posts: 2 Rating:
Dear experts! I have a Field PG M5, and I wanna connect with S5 PLC through AS511 interface.. Now I have RS-232 to TTY cable but I don´t have installed Step 5 software on my physical machine.. I´m trying with a virtual machine (VM Ware) with windows XP and step 5 (that is because my PG has Windows 7 by default and the pages of Siemens says that Step 5 only has compatibility with Windows XP SP3). Can you advise me how I may do it? I was configuring a serial port at the virtual machine (baudrate, COM, etc.) but the Step 5 software can´t to go online.. Best regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/11/2017 6:08:01 AMNew subject after splitting |
10/12/2017 8:42 AM | |
Joined: 10/24/2011 Last visit: 1/23/2023 Posts: 71 Rating:
Hello, I use VMware machine WinXp SP3 for Step5 with this S5 USB cable without problems. Which cable do you use? Standard COM cable 9pin <=> 15pin? Did you install another Siemens SW in your WinXP machine? J. |
Last edited by: Jenda at: 10/12/2017 8:43:37 AMLast edited by: Jenda at: 10/12/2017 8:46:16 AM |
