9/29/2020 7:07 AM | |
Joined: 9/19/2014 Last visit: 8/12/2022 Posts: 70 Rating:
Hello, I need advice on using the filter-program. I tried the filter with simulation it works perfectly (FB+DB+OB35), but when i tried it on real hardware program works wrong with the same program , concretely doesn't work filtering parts from MD 204 to MD 208(MD 592 to MD 596). MD 208 has a null value. No any error and mistake. I added the blocks on working program. I can't stopping the system. ------------------------------------------------------------------------------------------ |
Last edited by: andreyb at: 09/29/2020 08:58:32Last edited by: andreyb at: 09/29/2020 08:59:35Last edited by: Jen_Moderator at: 09/29/2020 11:15:22New subject after splitting |
9/29/2020 9:04 AM | |
On the picture with simulation it is working. On real PLC doesn't.. |
9/29/2020 12:08 PM | |
The same program on the real hardware. |
9/30/2020 10:07 AM | |
Helllo, thanks for answer. Connection in the Filter in attachment. The filter from the topic https://support.industry.siemens.com/tf/ww/en/posts/analog-input-filtering/7175?page=0&pageSize=10 .
AttachmentFilter.zip (118 Downloads) |
9/30/2020 11:49 AM | |
Ok https://youtu.be/gKkPTkSWPxc real hardware. When I tried opened FB block online appeared warning message. "coding error". So I cannot show screenshot. May you look video? https://youtu.be/3yEls1AtToY simulyator. |
Last edited by: andreyb at: 09/30/2020 11:51:21Last edited by: andreyb at: 09/30/2020 11:51:41Last edited by: andreyb at: 10/01/2020 13:11:17Last edited by: andreyb at: 10/02/2020 05:01:00 |
10/2/2020 12:58 PM | |
Hello i changed the block from scl to stl and made screens needed blocks with simulation and with real hardware. Attachmentscreen.zip (120 Downloads) |
