11/28/2024 4:00 PM | |
Joined: 11/18/2024 Last visit: 12/4/2024 Posts: 1 Rating: (0) |
Hello friends, I have a redundant system with a CPU S7 1517 H (6es7500-0hp00-0ab0), the other day I received an IE/PB LINK HA for PROFIBUS communication, it interacts with the CPU firmware version 3.1, I have firmware version 3.0, there is not firmware for 6es7500-0hp00-0ab0 on the Siemens website for the article. Can I install firmware for 6es7517-3hp00-0ab0 on my CPU and will it work? or is there firmware for downloading on CPU S7 1517 H (6es7500-0hp00-0ab0) ? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 11/29/2024 07:50:46New subject after splitting |
11/29/2024 12:08 PM | |
Joined: 5/6/2022 Last visit: 1/17/2025 Posts: 535 Rating: (109) |
Hi Stifler32, I have been reviewing the information and it does not seem to be possible to upgrade your CPU version with this updated version. In this case, I recommend that you review the information specified in the 'Product note' of the new firmware version V3.1 where you will find configuration information and options that exist with this new version that I think may help you: I hope it can clarify your doubts. Best regards!
