3/10/2009 5:04 AM | |
Joined: 9/27/2006 Last visit: 12/6/2024 Posts: 12301 Rating: (2691) |
Hello gonzela; As this is your first WinCC project, I really recommend that you study the manual "WinCC v. 6-Getting Started": http://support.automation.siemens.com/WW/view/en/17356933 It will get you through the most important steps in setting up a WinCC project, such as creating the project, setting up drivers, creating tags and assinging them to PLC addresses, preparing and animating screens.... You can easily adapt the example project to your own requirements once you understand the basics. And you can use PLCSim with WinCC projects; the following document shows you the setting you should do in Step 7, PLCSim and WinCC to get this setup working: http://support.automation.siemens.com/WW/view/en/21914005 Hope this helps, Daniel Chartier |
3/10/2009 2:01 PM | |
Posts: 2 Rating: (0) |
Hi thanks for your reply I have read the manual but I can not link the tags with plc I need the steps in detail Thanks |
