12/6/2022 2:58 PM | |
Joined: 4/28/2015 Last visit: 9/25/2023 Posts: 3256 Rating:
Hi, the FS:01 has been delivered without pre-installed Industrial OS, that's why you got a red STAT LED. To update the firmware to the latest version, at first you need setup the Example Image V1.1.1. A setup guide can be found here. After that you can perform the firmware update, how to is described here. After that you can use the latest Example Image V1.2.2, node-red is pre-installed and autostarted. An Industrial OS for the new firmware version is still not released, I am awaiting this the next weeks. Another option is to use the Industrial OS V2.2 with pre-installed firmware on your IOT2050 FS:01. If you want to go this way, then please send a DM to me with your email address. Best regards! |
