8/16/2006 4:48 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
You can program your own buttons, perfect when using WinCC with a touch screen http://support.automation.siemens.com/WW/view/en/729703 The Analog / Digital Clock ActiveX Control takes its format from the OS settings ( Control Panel -> Regional Settings ). So simply set the format here to change the display in WinCC. NOTE:You must ensure your Regional Settings are English(US) and not English(UK). Finally, please can you use the sub-forums for posting. So this should be inSIMATIC WinCC |
8/16/2006 5:47 PM | |
Found this FAQ http://support.automation.siemens.com/WW/view/en/748948 Tested it and found that I didn't need to switch to the Form view. So in the Graphics Designer, hold down the CTRL key and double-click the ua control. You can then resize the columns [;)] |
8/16/2006 6:17 PM | |
Posts: 13 Rating:
It works. Thank you so much. I believe this is just one of all SOS (Secrets of Siemens). [:D] |
8/16/2006 6:40 PM | |
