10/22/2012 3:05 PM | |
Posts: 59 Rating:
Hi Can you explain yours problem? Would you do position sync. between Master Axis and Slave Axis. so would you lock two Axis as position or Speed? best regards
7/26/2017 1:56 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by jerryvdk is split to a separate thread with the subject Want to permanently gear this two motors/Axis in 1:1 gear ratio. Can I use fixed gearing TO to achieve this?. Best regards |
