10/4/2010 4:10 PM | |
Joined: 5/7/2010 Last visit: 8/6/2012 Posts: 13 Rating: (2) |
Fromyour information I can't say that the FM352-5 will meet your needs but it will output 8 channels of PWM at 50 KHZ. It will also input 8 channels HTL at 200KHZ and 3 channels of RS422 or an encoder at 1MHZ. Theprocessor runs the internal program in parallel in 1us so the response time, input to output, is on the order of 3us. You can find the manual at: https://support.automation.siemens.com/WW/adsearch/resultset.aspx?region=WW&lang=en&netmode=intranet&ui=NDAwMDAxOAAA&term=FM352-5&ID=9240171&ehbid=9240171&docid=9237692 Hope this helps. RA |
