7/21/2017 7:50 AM | |
Joined: 8/25/2006 Last visit: 6/1/2023 Posts: 2181 Rating:
Hello. Which device you want to be the DP master in your system, CM1242-5 or FM458-1DP? FM458-1DP can be only the master on the bus, it can't operate as slave. For configuring CM1242-5 as slave for FM458-1DP you need to configure CM1242-5 slave in HWConfig with this GSD. |
