1/3/2016 1:38 PM | |
Joined: 1/21/2013 Last visit: 10/1/2023 Posts: 4617 Rating:
Hello, mmmh can you post your program to see if you have some problem? And you have already seen this: https://support.industry.siemens.com/cs/us/en/view/2746047
1/3/2016 3:33 PM | |
Joined: 10/28/2014 Last visit: 9/28/2023 Posts: 63 Rating:
Hi, I have attached the test project which I am using. The input I2.1 at the SW gate input is of a sensor which gives me my zero position. Also, I had forgotten to mention earlier, I tried the small configuration which is given in the manual attached in your previous post. Configured the FM as 24V Initiator. In this case my gate contact I0 LED was working fine but the CR LED was not lighting up and neither was my counts changing AttachmentTest_fm.zip (134 Downloads) |
