5/16/2008 12:10 AM | |
Posts: 5822 Rating: (412)
Hello, I am sorry but Joerg is right. The problem is that the AUI/RJ45 Transceiver you have is only connectable to the Uplink of the SSV 104. So if you connect the PC there it will work but be aware, you have to activate the Uplink and you will have to be aware that if the PC drops out, the complete Hub is down! J_Bell |
